Unable to obtain metadata for Blu-ray series
Right, if you are ok with less than perfect metadata you can name each disc as a single episode, and get the correct info for that specific episode.
So maybe disc 1 has Ep 1-4, you could name that S01 E01. Disc 2 has E 5-8 so you could name that S01 E05, etc…
It beats not being able to view it them at all in the library.
So @Azure just needs to name the discs as tv episodes after all.
Would the full folder structure need to be …
Cosmos 2014
    Season 1
        Cosmos 2014 S01E01-E03
            BDMV
        Cosmos 2014 S01E04-E06
            BDMV
        Cosmos 2014 S01E07-E09
            BDMV
        Cosmos 2014 S01E10-E13
            BDMV
Or is it less rigid than that?
Yes, that should actually work. :slight_smile:
