Unable to fetch metadata for specific content
I have mkv files for Ghostbusters II and also for Alladin the King of Thieves. Neither of these are available from the metadata search in Infuse. I know Plex is able to fetch the Metadata and Artwork. I don’t see any way of manually overriding this.
How can I do this?
I’m using Infuse 6 on iPad Pro which I just installed today
thanks
Ricardo
Can you provide the file names for both movies?
Try “Aladdin and the King of Thieves 1996.ext” for the Aladdin one.
It looks like you have one too many "L"s in Aladdin. :wink:
For the other try “Ghostbusters II 1989.ext”
Replace the “ext” with the file type you have like MKV, AVI, MOV, etc.
Thank you so much!
The Ghostbusters II took spelling it exactly and waiting a little bit longer
Anytime, enjoy! :smile:
