I just aquired an Apple TV 2, but it is updated to 5.21. I’m trying to do the jailbreak, but it will not enter DFU mode. I believe it is the cable as I have read that causes issues.
The first cable I used, nothing would happen when plugging it into the Computer. I then went and purchased one from Radio shack, and now my cpu will say “failed to install” or soemthign similar when plugging the ATV into the computer. iTunes does not recognize the apple tv plugged in either.
I think this is the reason it will not enter DFU mode.
So, what cable should I get? Anyone know of one that is known to work?
well, you have to wait until season pass is update for 5.2.1 because currently you can’t jailbreak that version. in the mean time try using another port on your computer.
the same problemI alsohad it… do not know whybut for meit is important tousbcable after severalchanges pc, laptop, cable, found onemini usbcableworkaswell the solution: change mini usb cable
I’ll tell you…for me isvery confusing…butis definite isthe cable
Iandused the same cable, about 50or more times andat any moment, stop working. I havemore cable …use anothercableand nothing. othermoreandwork… all from the sameproduction or same brand
