I am getting this on macOS. I don’t know the exact error. Internet is working fine.
V2QKV
V2QKV
Can you connect via web browser to their web site?
Yes, I can.
Do you have any other devices with Infuse on them you could try? I had this occur a while back and a restart of the device seemed to remedy it. After the restart of the ATV it would again fetch subs so maybe a restart of the Mac would help?
Just a thought.
It appears that currently Opensubtitles is operational on the status page.
Also, are you by any chance going through a VPN?
Or are you using something like Little Snitch?
There are many network related errors in your logs when Infuse tries to connect to certain services.
No, I’m not using anything.
And I gave you the diagnostics code V2QKV
The error messages are not neither descriptive nor actionable. That’s bad coding practice.
