Unable to connect to APPLE TV using FUGU
I have recently installed the 3.2 onto my apple TV, but the FUGU could not connect to my APPLE TV.
Please help!
The port field should be blank.
(A factory restore will change host)
Open Terminal and enter the command below:
sudo rm .ssh/known_hosts
When prompted for password enter your computer admin password
Restart fugu and try to connect.
Note: if unsuccessful change the AppleTV.local to your actual ip address (i.e 10.5.2.8) and connect as usual. I can connect without having to enter the port number.
