I was using InFuse v6.5 pro OK on my appleTV 4K last night and yet today ( after tvOS 14.0 update ) InFuse v6.5 prohas broken.
It tells me that a “Connection cannot be established” to my NAS ( which is still working 100% for my iPhone, iPad, MacBook , MacMini and LG OLED TV )
I removed the share from InFuse expecting to be able to reconnect , but even though InFuse v6.5 pro actually displays all available shares on my network ( incl my NAS ) , I am unable to create a connection to my NAS. Connections to my MacMini Server and WIndows10 Gaming Box also fail.
This is the one thing I cannot easily test as I don’t have another tvOS app that can browse SMB shares.
I also don’t even have a simple portscan / lanscan app on tvOS
Unless you have a suggestion?
I forgot to add that InFuse v6.5 pro is still working 100% OK from iPadOS v14 and iOS v14 from my other devices on the network ( if this helps )
It is strange that it is just the TV4k
{Update} I forgot to add that because I use iCloud Sync, the NAS entry keeps getting re-populated in inFuse on TV4k , but if I try to open a Favourite, I je=st get the same "a connection error has occurred "
OK - Not sure if is an Encoding Issue, but VLC does not play my Media. It does however connect to the NAS and display my Movie and TV Show folder structure.
Even though my other Apps are functioning, I will reset the TV4K and see if this resolved the issue with InFuse v6.5 pro
Even after resetting the TV4k ( and also trying to reinstall tvOS 14 ) I still have the same issues with InFuse v6.5 pro
I have noticed that shows and Movies I have been watching on my iPhone / iPad no show as “watching” on the TV4k , but if I try to continue to watch on the TV4k , I continue to get the “Connection Error”
I did a complete TV4K Wipe and DFU tvOS 14 restore. I am still getting the same issue with InFuse v6.5 pro not Connecting and Indexing the files on my NAS
I have just uploaded my Technical Details = 7KZDK
Yes , At the time i moved from v5 → v6 I had decided to purchase the single product rather than the Lifetime Upgrade. So both v5 and v6 exist in my ATV / TV4k purchase history.
NC_Bullseye - thanks for the link. I never had issues with InFuse v6.5 pro from iOS , iPadOS connection to the NAS after the upgrade.
And I am still unsure why removing v6.5 pro and installing v5 and reconnecting to NAS fixed the issue on my TV4k after tvOS 14.
The only issue is that I have now lost all my Sync’d “Watched” indicators
That was a reply to honolulu, it should have shown as that on my reply in the quote I referenced. Sorry to confuse.
I’m guessing that when you deleted v6.5 and then installed v5 and then went back you probably fixed an issue in the network settings when you installed 5 and fixed it when you reinstalled 6.5.
