Top shelf doesn’t seem to be working on tvOS v18.0 and Infuse v8. Anyone else having this issue?
Can you describe what you are seeing?
Do you see the Up Next List (top row with landscape artwork) if you open Infuse?
Do you happen to have Parental Controls enabled on the Apple TV? If so, this can prevent the Up Next List from appearing on the ATV home screen.
Grrr, it was restrictions enabled causing the issue.
Thanks for your help!
