I just wanted to make the dev team aware that Infuse is the perfect tvOS video player app, however I need to manually go through and set audio boost to 400% on every video so that I can actually use it with my BT headphone.
To be honest a setting allowing default audio boost, ideally to pass 400% (it’s the users job to make sure it won’t go too loud to get their ears damaged) would solve the entire issue.
Also, BT audio is NOT an Infuse problem, but ATV/tvOS issue I have vetted. Thanks team Firecore!
