tvOS 17 player problem
I upgraded both my appleTVs to tvOS 17 after I verified everything works on it and then updated the second one.
I missed a few things:
  1. playing a cropped HDR file and only the middle area was active - meaning the very top and bottom of the screen were missing (black) - the infuse menu and scrubbing interface were just cropped - only their middle appears.
  2. I’m seeing some micro judder on the very same file.
Here is the video part of the media info:
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Duration                                 : 2 h 7 min
Bit rate                                 : 24.4 Mb/s
Width                                    : 3 840 pixels
Height                                   : 1 604 pixels
Display aspect ratio                     : 2.40:1
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.166
Stream size                              : 21.8 GiB (97%)
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : BT.2020
Mastering display luminance              : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 1236 cd/m2
Maximum Frame-Average Light Level        : 677 cd/m2
If you’re playing Dolby Vision on a TV that does not support DoVi (like Samsung) you may try disabling the ‘Extended Dolby Vision’ option (found in Infuse > Settings) to avoid potential issues with the Apple TV sending DoVi video output.
I would also check to ensure the Match Content options are still enabled, as these can sometimes get toggled off when installing OS updates.
You’re right, if I disable extended Dollby vision, it works correctly.
