Has anyone had a feeling or been sure their audio sync on ATV4k Infuse is a little off after the tvOS 16 update? It feels to me the video is just a smidge enough behind the audio to give me nerves, I’ve switched to other streaming apps like Prime or Hulu, and it seemed fine.
Playing movies from my Plex server with Infuse 7.4.5. Nothing changed except the tvOS update. Thanks.
-Alan
EDIT: Found that turning off match frame rate does help.
Sometimes (especially when watching Anime) I set playback speed to 1,25%. Then with time Audio and Video gets out of sync (note, that it’s not out of sync directly, but with time)… I don’t know, if it’s related to tvOS 16 or the latest Infuse update.
That’s a separate issue that’s affecting videos being played at faster speeds on iOS devices. It’s been happening for months, before both iOS 16 and the recent Infuse update. I’m following a different thread that was posted about it and have contacted support, I’d encourage you to do the same to help them narrow down the issue. The more, the merrier!
Me as well is driving me nuts crazy
I got so hyped from using this app but now I just think it’s not worth it all the effort switching to it
Nothing like good old hdmi cable or normal usb tv port
If you’re seeing issues here, you might try resetting the video settings in Apple TV > Settings > Video and Audio, then configuring things to your liking.
There have been a few cases in the past where this has helped, and it’s possible the tvOS 16 updated caused some issues here.
Maybe try the suggestion since Infuse uses it’s own player and audio handling where the others use Apples? It wouldn’t be the first time a major OS change caused problems.
Plus that may help eliminate other possibilities by trying this.
Didn’t help me either. Still continuing with the “no match frame rate” workaround. Also found that this is a workaround for ja current YouTube app bug, where the video starts late because the app sets the frame rate but doesn’t wait for it to change before playing.
To re iterate
ATV 4K 1st gen
HDMI to LG C1 65”
Storage USB 3 Drive connected to router
ATV Connected to router with Ethernet
Read speed test from infuse 700-800Mbps
