Umm while I have your attention, if I may On the all TV Shows screen, I see just a folder icon for all of the shows that have multiple seasons, and the icons and metadata for unwatched etc is not shown. For shows with just one season, all good, show icon and unwatched status. Do I need to do anything to get that for all of them?
You might try on one of the shows with multiple seasons to group each season in a folder. The folder name needs to be Season 01, Season 02, etc. I believe. Try that on one and see if that gets you what your looking for.
Using a sub-folder for every season is definitely the way to go for multi-season tv shows. Plus this is the exact same recommended setup for a Plex Media ‘TV-library’, so its a win-win if you ever want to use a Plex server to stream to almost any modern digital media center. I am, however, a little unsure about the rules of Infuse’s library setup…
Do all TV Series & Episodes need to be under a “TV Shows” parent folder? And all Movies need to be under a “Movies” parent folder? Or can a TV Series (like ‘Planet Earth’) coexist in a folder with similar Movies (like Disneynature’s ‘Oceans’)? I am wondering if Infuse’s Library View (tvOS) would get confused if I make a “Documentary” folder, and place ALL nonfiction / wildlife / educational titles under that folder, no matter if they are doc films, doc tv series, doc tv movies, etc.
I was looking in the wrong place. The Library view is working perfectly. And for reference, the way I store TV Shows (1 directory for each, no season directories) works just fine with Plex and Kodi.
