TV Season_Settings
It is recommended to add custom settings in the season menu to skip the opening and ending time
Am I the only one who wants to skip the opening!:sob:
no, but it took me a while to understand what you meant.
Just to be clear: It’s about automatically skipping the intro and credits scenes in tv shows.
I would love that, but I guess it’s not that easy to implement. How would Infuse know where an intro starts and where it ends?
I can tell when to skip
then tell infuse
Because Chinese TV dramas have a fixed beginning and end
I want to skip the step of fast forwarding every episode :fast_forward:
I do not know English
hope you understand
All of the above is Google Translated
Just as a suggestion while this is being requested, have you tried turning “on” “Chapter Controls” so when you click the forward or back it jumps to the next chapter instead of “x” seconds? Maybe your shows have the beginnings and ends as chapters and you’d only have to click once to skip them. That may make it easier than fast forwarding.
The key is that the beginning and end of the program are not in chapter control.
Maybe you can also give the time of the “chapter control” to the user to fill in!
Please
:pray::pray::pray::man_bowing:t2:
