i know this subject has been beaten to death but anyone else noticed that tv shows are not getting metadata? (yes my folders are marked as tv shows)… metadata works fine with movies but not with tv shows… seems like it doesnt recognize most shows, even if they are exactly the same as in thetvdb.com…
Mine mistakes The X-Files for National Geographic X-Files or whatever, anyway I find it strange that the mother of modern tv shows is mistaken for some documentary.
Don’t know if firecore can do anything about this because the metadata is probably pulled from an external source.
Check out my post here and the one right after it: http://forum.firecore.com/topic/7758#comment-37879
I’ve checked it, I’m sure the renamer is a great solution… If you use Windows.
