I have an issue with my Infuse Pro :
I’m subscribed since October and today when launching an MKV, it put me back at the Subscription Selection.
I tried the Restore button, without Success.
I tried to click on Annual again, and it said I was already subscribed and right after: Network error (my internet works just fine)
It seems like the thread you’re mentioning does not have a working solution: despite the steps you’re providing I’m unable to access the pro version I paid.
Make sure that the account that purchased the Infuse subscription is default user on the Apple TV. It can’t be one of the added users since only the default users account has the iCloud connection.
Hello to the forum, I am also facing the same exact issue in different machines.
Apple TV under ios 15.3 and beta 1 of ios 15.4
iPhone 12 Pro Max under ios 15.3
iPad 12.9 M1 under ios 15.3
Single account on App Store, already done what James has suggested, unfortunately no luck
When trying to restore on all devices button shakes and I get an error that the network is not available. “Network Error Check your internet connection and try again”
Have already echanged several emails with support of Firecore but no luck.
Are you sure you’re using the same Apple ID on all devices?
It shouldn’t actually be possible to subscribe to the same thing twice using the same Apple ID.
I would wait and see if you get a receipt from Apple (this may take 3-4 days). If it does come through, check to see if the email address listed on that receipt matches the email from your original receipt.
Hello je le même problème avec tout les compte famille
Impossible de restaurer l’achat de infuse pro sur tout les produit Apple
J’aimerai bien une solution
Merci et à très vite
