I have the lifetime pro licence as well as a Plex Pass and am currently attempting to get my collections from Plex to properly show up in Infuse. But I’m having troubles.
With Library Mode enabled in Infuse I do see a “Collections” section and when I browse into it it appears to show all of my Movie collections. But for some reason none of my TV Show collections show up at all. Another issue is when I go to the “Movies” section and browse all it shows all the collections there as well rather than just showing the actual movies. I would think the collections should only show in the “Collections” section and only actual movies would show in the “Movies” section? Currently it seems a bit messy in the “Movies” section. Like the “Movies” section currently shows a bunch of collections, followed by all the movies, followed by more collections. When I view my library in the actual Plex app it displays properly with the Movies under the “Library” tab and the collections under the “Collections” tab. Just to note, in my Plex server settings for each lirbary I have the “Collections” setting set to hide collections on the library tab but still show their items. But that doesn’t seem to get applied to Infuse. Also if I change that setting to “Show collections and their items” then for example the TV Shows collections on the Apple TV do show up but only by going to Favourites > Server > TV Shows library. It does not show in the regular Collections section or the regular TV Shows section of the homescreen the same way the Movies collections do.
Then when I try disabling Library Mode I have other issues like the all “Movies” section only showing a single movie but the “Recently Added in Movies - [insert server name]” section shows all of my movies and collections. It also doesn’t have a separate “Collections” section like library mode does. So the collections are still a mess and the “Movies” section isn’t working properly given it only shows the one movie. The non-plex “Recently Added Movies” and “Unwatched Movies” also just show a single movie which happens to be the exact same movie that the “Movies” section shows.
So I’m wondering what can be done to fix these issues? I love Infuse because it supports things like HDR10+ and Dolby Atmos which the official Applet TV Plex app does not. But the current mess with collections is a major issue for me because I use a plex related tool called Kometa to create all sorts of varying collections. But not being able to browse them or browse just the movies alone is an issue.
I know you can get TV collections to show on the Infuse Home Screen if you pin them to the Plex Home Screen. But given that I use a tool made for Plex, Kometa, to create a ton of dynamic/smart collections that’s not really a solution. Having that many collections on the Home Screen would be a terrible experience to scroll through.
Thanks!
