.ts files supported (recorded movies from for example a Dreambox) ?
Hi there,
are .ts files supported I store on a NAS after recording them with my dreambox.
Are these TransportStream files supported with you product ?
Thank you for a quick answer (mabye wanna buy your product today)
Thanx,
speedtriple
They should, but if you want to send in a sample file we can check to be sure.
James,
I think I can answer the question speedtriple placed here. I’ve tried to play a movie that was recorded with a Dreambox DM8000 SAT receiver but it can’t be played back with aTV Flash.
I can browse over the Dreambox (Linux) and find the file, but screen will be black.
The dreambox writes the movies in the TS format. As far as I know it is almost the same as MPEG.
Please let me know how I can send you a short record in TS format for investigation.
John
Dear you at Firecore,
I have the same problem with viewing .ts-files
Are you working on a solution?
Bst rgds,
Gustav
I’d also really much like to have .ts files working (I have DM7025+). The movies are displayed well in my aTV, but I can’t get the subtitles working.
Thank you very much!
-Pka
