Yes, Fugu has trouble removing directories that contain any files.
You need to remove the files from the directory, then the directory can be removed with Fugu.
That’s an option that i try out in the past.
But if the directory is empty it can’t removed!
This are directry’s that had copied from the orginal HDdisk.
And why can’t renamed it?
The directories need to be empty before you try and remove them.
Under the SFTP menu, select show hidden files. Now remove all the files from within the directory you wish to remove. Once the files have been removed, the directory can be removed as well.
thks all is oke now.
Hidden files ON and remove all insite directory , then its done.
