When trying to transfer files with Transmit, I get an 160 error (permission denied). Thanks for any help.
Does this also happen when using the web upload?
How many files are you transferring at a time?
1
Are any login details being entered, or are you connecting anonymously?
Can you try using Cyberduck to see if the same issue pops up?
Thanks for the help. Found my problem. I had Transmit pointing to the Inbox. Cyberduck worked fine, so I knew I had a problem with my Transmit settings.
Now I need to write a review on the App Store.
Great! Thanks for following up.
