transfer files w/ usb flash drive
Hello to all,
My main computer being at the office, I would like to avoid having to carry it at home each time I want to transfer non-iTunes files to my ATV.
Can I eventually use a flash drive that I would just plug into my appleTv to copy the files to the Nito folder?
Mark
Yes, if you want to transfer media from the external (flash) drive to the internal drive (or vice versa) you can do so by following these steps.
  1. Locate the file or folder to be copied through the nitoTV → Files menu.
  2. Highlight the file/folder, press the right arrow and choose the copy option.
  3. Navigate to the place you would like to copy the files to, press the right arrow and choose the paste option.
Thank you Max, I’ll try that this evening!
Cheers.
Mark
