Just noticed that it’s days that Trakt sync stopped working. I am an Infuse 7 Pro user and I can already tell you that I have already tried to disconnect and reconnect trakt via Infuse preference/option settings but didn’t work.
I have infuse currently installed on 2 Apple TV and one Mac, tried that on all the devices but nothing changed.
Any suggestions? I really use trakt and it’s an important element of Infuse.
It’s Infuse Pro 7.3.10 (4085). Don’t see any update available.
Trakt I just use it to keep track of what I watched and still need to watch. I check the trakt calendar and having Infuse not working properly it’s just confusing.
Does marking something as watched manually sync to Trakt?
Do you have Metadata Fetching enabled in Settings > General, and are the problematic items matched to the correct titles? Metadata Fetching is required in order to use Trakt.
