Trakt problem with Infuse 5
Hi
I cannot sync my trakt progress to Infuse 5. It worked great on infuse 4. The files are the same and I have tried to sync trakt several times, with no luck.
Please help!
/N
Can you provide a bit more info about the issue you are seeing?
When logged into Trakt, items you watch in Infuse will be synced to your Trakt account. If you are also a Pro user, Infuse will also pull down watched status and progress from Trakt.
Hi. I have this problem. I’m infuse 5 pro on 3.1. I’m linked with trakt on 3 devices and prior to version 3 watched indicators synced across devices but now has stopped. I’ve logged off and back in on all divices and this doesn’t solve the issue. Thanks. Adie.
