Torbox WebDAV
Just got on torbox, trying to connect using WebDAV , but keep getting error “ unspecified path “ , anyone got a fix to this .
Did you happen to find a solve for this? I’m running into the same issue
Yes I did , just try and put some content in your firebox library, that should solve it
