Scenario: Top Shelf shows correct data, Continue Watching, Recently added. If I open the app then back out after or / during a refresh the top shelf craps out and shows maybe 1 or 2 posters (usually a couple of movie posters). Nothing else can be seen such as recently added. I need to go back into the app to fix this.
I have this issue on both the most recent Beta and current TVos versions of the app.
The issue happens not only if I back out of the app too quickly but also happens randomly.
You may want to include the model of ATV and generation, the tvOS version number, and if you’re using a server like Plex, Emby, or Jellyfin and if so what version numbers and if your using direct or library mode.
