I’ve just made the switch from Infuse tvOS 4 to 5.6.7
In v4 the top shelf used to go directly to the program, instead it now goes to the menu but as it would in V4.
Opening infuse 5 directly opens up the new main menu.
Any ideas?
This is related to a bug/quirk in how tvOS works.
Removing Infuse 4 should allow things to work as expected.
Excellent. Working as expected. Thanks!
