Top Rated TV Shows Filter
Hi, Is there a meta limitation to providing a “Top TV Shows” filter in the same way it is provided for Movies?
Was just editing the Home Screen section and noticed that Top TV Shows was not a option but the ratings for the shows is present.
I believe the problem is that TV shows can only be rated by the episode, not the series so you could have an episode rated “10” but the rest are 0-3. That with the additional variable of number of episodes available and number of episodes rated makes it nearly impossible to rate TV shows accurately and as a whole.
Compare that to movies where you are rating the one and only variable. :wink:
Okay that makes sense. Can’t they use a simple array average calculate function (assuming the code is swift).
Any how I was just making a suggestion.
