It’s ok! I’m glad to help.
Set to Auto. And no settings were changed from before the latest update.
Diagnostics: W4KJA
Diagnostics: W4KJA
I believe james was asking about the device settings like on the Mac it’s under the Settings > General > Language & Region. What do you have set for “Preferred Language”?
English.
Did my report show anything out of the norm?
Is this US English, UK English, Australian English, or something else?
Experiencing same issue after updating to 8.4.5, posters have no titles. Metadata was set to English (United Kingdom) and Artwork to Auto. To get titles back on posters I had to set Metadata to just English.
Anyway what I’d like is to set Artwork to Original and Metadata to English which at the moment is impossible because as soon as I change Artwork to Original the Metadata changes automatically to also Original. And if I then change the Metadata to English the Artwork also gets changed automatically.
Will we see an update for this issue @james ?
Is it an app issue? TV shows don’t seem to have the issue.
I’m eager to get this fixed lol any leads on what it could be?
We’re working to resolve this. It seems to be a flaw in some of the language fallback logic that can appear in some cases.
Should have a fix available soon in 8.4.7 8.4.6.
Thank you!
It won’t be in 8.4.6?
I see it in the notes for 8.4.6 so maybe you put .7 by accident?
Appreciate all the help.
Sorry, yes 8.4.6. ![]()
I have it too. It’s on iOS and MacOS - just to mention it’s a cross-device issue. ![]()
Hi James, please note the issue is also present on tvOS.
Can we hope to see 8.4.6 this week @james ?
Any updates on the fix for this?
I have tried uninstalling the app, deleting the metadata cache, rescanning all media. NO solution. Plex library is unaffected, and when scanned by infuse, shows the correct posters.
BUT I like the infuse UI better for everyday use.
PLEASE FIX THIS SOON!!! thanks CD
