TMDb for Series - Order Selection possible?
Hi there =)
I was wondering if it will possible to use a specific order from TMDb for a Series. For example: I have a series that is not matching with the Order given bei TMDb. TMDb has wrongly just put 1000s of Episodes in one Season. But there was an order created, that would have the right season logic etc behind it. Are we able to choose for a specific series the order? I think prom API side of TMDb this is feasible.
Thank you=)
Look at the first item under “7.2.x (pending)
:wink:
