Titles duplicates
Hello team,
With the last update, I see various titles duplicated, when only I have one file per each movie. Any fix to this problem?
Thanks in advance and best regards.
What type of device are you streaming from? Are you using UPnP or DLNA by chance?
In some cases, duplicates can appear until UPnP/DLNA devices finish their own rescan. Once this is done, the issue should correct itself in Infuse.
Of course, you can avoid this whole issue by connecting via SMB or NFS. :slight_smile:
Hi!
I’m using an UPnP device, WDMyCloud under High Sierra OD. This problems appears with the last update. Before it, everything was fine.
How can I connect this vis SMB?
Thank you and best regards.
Hi James, problem solved. I connect the external HD via NFS and better, even some TV show that before showed wrong, now it shows perfect.
From my side, this theme is closed.
