Titles duplicate and lose metadata when downloaded
I have a OneDrive folder with all the metadata synced manually. But every time I download one of the titles locally on my phone, it creates another version of the title without metadata.
Can you provide a bit more info on what you are seeing?
Assuming Metadata Fetching is enabled, Infuse will automatically hide the remote copy in the library and just display the local copy to avoid confusion.
However, if you are using your own metadata then there may be cases where duplicates can be visible.
Hi James! Some details:
  • My library uses my own way of naming titles. Because of that, I had to sync everything manually.
  • I synced everything manually, but using your metadata online search engine.
  • There is no extra metadata on my movie folders to avoid any sync confusion.
  • This happens everytime I download a title.
