I found that the Infuse 6 pro is removed from the the upcoming feather. You said that the the TVDB database will changes to the TMDB in the upcoming feather in the past September. Just wodering when can it be done? thanks.
The switch to TMDB was made in Infuse 6.7, which was released at the end of September.
