Time Capsule to Atv using A to A USB Cable
Hi All,
Has anyone tried this with any sucess?
Andrew
The Time Capsule uses it’s USB port for printers and external hard drives to add to the amount of space available for backups and such. The Time Capsule probably doesn’t have the right hardware inside to tell a computer that it is a USB hard drive. Just as if the AppleTV can not be used as a USB hard drive. The USB chipset installed would have to be one that can be used as a IDE/SATA to USB bridge and I don’t see that being installed in either device.
thanks for your reply, i can confirm that having tried to do it, you were right, it doesnt work!
