Just updated to Infuse 5 Pro from Infuse 4 Pro. Really liking it but found a couple of issues:
Thumbnail generation seems not to work in version 5 as good as in 4. Video files with codec H.264 / MPEG-4 part 10 often fails to generate a thumbnail but the video can be played. Can you fix this?
Can you make the thumbnail bigger when in list view? Or maybe a way to list the filename when in ”gallery view”?
