Thread For Beta Testers.
Hi everybody, I really would like a dedicated thread for beta testers. I’m having problems creating the drive. The installer takes less than five seconds to finish. The terminal installer took longer and worked fine. Any help would be great. Admins feel free to move this to the right place.
Version 3.1.1b2
Thanks. :smiley:
Are you copying the app to the hard drive before running it? The disk image contains core information that is necessary for the install.
Try running it directly from the disk image.
Yes I put the app in my applications folder. I ran from the disk image and it worked fine. :oops: Maybe you should make that very clear in the PDF.
Thanks For The Help. :smiley:
