This Device is not supported by SeasonOnPass
getting that message everytime i try to jailbreak the appletv 5.0.2… It just won´t work
Anyone having the same problem?
Plz Help
i think you want to try to jailbreak a ATV3. that will not work
It says version 5.0.2 IOS 5.1.1
How Can i Tell the difference… ? A friend Bought in the States in middle of march and i’m not sure hé World have noticed
You can tell the difference by the max resolution it supports (see my sig).
Hmmm i guess you are right… It says 1080 HD- 60 Hz… Dammit
