i have some folders with many small video clips. Is there an option on TVOS to temporary activate continuous playback for a folder? Now I have to go go settings and activate continuous playback, and after watching some clips I don’t have to forget to disable it, because I don’t want it on TVseries and movies. If there is no such option it would be a suggestion for coming versions of infuse…
Yes, if you trigger playback by long-pressing on the folder (long-pressing Play/Pause on Apple TV) and choosing the Play/Loop/Shuffle options then Infuse would use continuous playback regardless of what the main ‘Continuous Playback’ setting is set to.
Hi James,
thank you for your answer. That is exactly what I meant.
