http://forum.firecore.com/topic/7279
adept this for 5.3
i tryed with ios 5.3 files and works
adept this for 5.3
[quote="nostre"]
adept this for 5.3
[/quote]
... how did you get around the two dmg files being 4.44 version and not 5.3 version dmgs?
How are you creating the IPSW in step 3...any attempt to create a IPSW file results in the "not elibible" dialog popping up.
[quote="zapper"]
[/quote]
I'm using Seas0nPass_444.zip not the latest seas0npass.
But that's the problem as 444 only generates 444 dmgs (and if you use latest seas0npass, it's like the instructions say, it won't give you My documents>seasonpass folder which you need to pull the dmg files).
