Tap fanart to start video playback
Hi James, why have you made it on iPad so that one has to tap specifically on the play button in the centre of a video’s rectangle image that is on every tile? Why can’t we just tap anywhere in that rectangle to trigger playback? Look at how YouTube does it: you don’t need to tap/click on the big red play icon…
Thanks for the feedback.
Moving this to suggestions for now.
I would beg to differ and argue that this is not a suggestion, but a bug.
When it comes to tapping the rectangle to bring up the Add File menu, one can tap anywhere in it, one does not have to tap on the + or Add File caption.
Please make this consistent so that the entire thing is a control.
Based on how you have to swipe down to close the movie details in the new library, it is probably safer to not accidentally start a movie instead of just a swipe. But assuming you have good accidental detection it could work. Also, it is consistent with how it works on on up next tiles right now.
Also, personally i find that youtube auto-start very annoying. Sometimes I just want to look at info, but can’t do that without starting…
You don’t have to swipe down. You can just tap anywhere outside of the “tile” area…
I suppose on the ipad, yes, but not much room on the iphone. Currently they are fairly consistent between the two devices.
There are some places where consistency is a good thing, but iPad and iPhone are distinctly different devices, so there is nothing wrong with certain deviations so long as they are for the better.
May I ask if there is anything that will be done about this as part of the usability improvements that are being driven at the moment?
