System storage bug when deleting files. (solved)
As discussed by many in the community, infuse on iOS, in my particular case iPadOS, has a difficult relationship with the OS when it comes to deleting files and releasing storage. Even though per 7.5.2+ update, the deleted files should have been moved to ‘Recently Deleted’ folder in the Files app, it appears to be bugged again as of iPadOS 17.1.1 + infuse 7.6.4. No files were found under ‘Recently Deleted’ after the deletion of 159GB worth of files, and that storage space was not released.
Due to extreme reluctance to restore the OS, after several hours, a ‘.trash’ folder was located in File System>Apps>Infuse>Documents using iMazing management tool. This folder was only visible when ‘Show hidden files and folders’ was toggled in iMazing, although no file was found in the hidden folder, the system claimed that it was exactly 159GB large. System storage space was immediately released upon deleting this folder.
Hope this discovery helps whoever came to search.
Hmm interesting. Were these files deleted recently or were these deleted some time ago?
If I recall correctly, they were deleted on the 18th of November. So at the exact moment of deletion, the device was running iPadOS 17.1 rather than 17.1.1.
Ok, and just to confirm you were running a recent version of Infuse at that point - at least something newer than 7.5.2?
I can’t be certain of Infuse’s version at that point. However with auto update on from the app store, there’s no reason Infuse could be any older than 1 version behind at any given time, if not the latest.
I just found this thread cause I just ran into this on my iPad Mini 6 on iPadOS 17.2, and Infuse 7.6.4656. I just deleted the files to make room for other ones and the space didn’t get released. I did it through the Files tab in Infuse, then tapping on the video and selecting delete from the 3-dot menu. The files didn’t go into the Recently Deleted in the Files app and now that storage can’t be recovered, I guess without that third party app for PC?
iPad Mini 6 on iPadOS 7.2, Infuse 7.6.5 (4656).
From searching, there used to be this bug a long time ago, but Firecore developed a workaround where Infuse moved the files to the Recently Deleted section in the Files app. However, recently it didn’t move the files there but got “deleted” from Infuse, and the storage cannot be freed.
It is the same bug as a recent thread which I responded to but it’s marked as “solved” so dunno if it still gets checked. It is not solved though, the OP just used a third party app on their PC/Mac to expose the file system and delete the hidden files manually.
I deleted the file with the immediate previous version of Infuse, probably 7.6.4. I can’t seem to reproduce it with 7.6.5 so it might be fixed but I still can’t recover the space of those previously deleted files. Is installing a third party program on my PC the only way?
As of Infuse 7.6.6 + iPad OS 17.2, deleting the downloaded file within the Infuse app or the files app still results in unreleased storage space. However, if you do not perform the above actions, instead delete the files via “settings>general>iPad storage>Infuse>documents”, storage space will be released.
Sadly this does not solve storage occupied by previously deleted files, but it is a viable option to prevent further losses in the future.
I could delete the files after a while. They appeared in recently deleted. Not sure what triggered it but I don’t think infuse updated, nor the OS. May have been a reboot but I’m pretty sure I tried that before.
I have been seeing the same issue: files I’ve been deleting from Infuse didn’t go to “Recently deleted” and space was never being freed. Instead I found them using iMazing in a folder called “.trash” under File System - Apps - Infuse - Documents.
These are all files I have deleted recently, on iPadOS 17.4.1 and with Infuse 7.7.5. So there definitely still is some bug there related to deleting files.
We have been doing internal testing and are no longer able to replicate the issue on our side. It seems Apple may have finally fixed this in a recent system update.
If you were seeing this issue before, please try updating to the latest iOS 17.5.1 release to see if this behavior still occurs when deleting files.
@james I am still having the issue so it’s not resolved. Similar/same as the above posters…
Infuse shows 12GB in iPad storage but I only have 2GB of files in Infuse. Recently deleted items in Files app is empty. I am on iOS 18.1 and the latest Infuse.
What does it show for metadata when you go to Settings > General and scroll to the bottom at Metadata?
170MB for metadata.
I’ve two files downloaded around 1GB each (2GB) and yet iPad tells me Infuse is using close to 13GB “Documents” storage. I can always add screenshots if that helps but the issue is definitely persisting. The only way to solve the issue is to completely delete Infuse and install and setup again :frowning:
@james I just ran into this issue again. This time on iPad Mini 7, iOS 18.5, Infuse Pro 8.1.7 (all latest as of today).
It doesn’t happen always, and I can’t tell which type of file or circumstance triggers this so it’s not 100% reproducible. iPad settings storage says Infuse is taking 172.94 GB but adding up all the “documents” sizes is only 133.06 GB so it’s a big chunk. I also noticed immediately after deleting the videos from Infuse’s downloaded Files tab then going to the Files app and only one video of the 4 I’d deleted was there, and deleting it didn’t free up the space of the other files.
