Synchro iCloud failures
Hello, since yesterday I haven’t been able to synchronize with iCloud, I get a failure
Does it say what the failure is? And what device and what version of Infuse are you using?
I have a message in the settings, icloud synchronization: last: failures I have this message only on the iphone and the apple tv (no problem on the ipad) 7.5.6 (4444)
If you are able to send in a quick report from your device and post the code here, we can take a deeper look.
hello, problem solved, icloud backups have been working since today
