Sync issue with lists
Hi everyone,
I have a quick question: I currently have 67 lists in my collection, but I see that only 14 of them are showing as synchronized (according to the ‘Synchronized’ tab).
The rest of the lists haven’t synced for days now, and I’m not getting any error messages. Does anyone know what might be causing this or what I can do to fix it?
Looking forward to your help!
What version number of Infuse?
What device?
What OS on that device?
Are you using Plex, Emby, or Jellyfin?
If so, Library or Direct mode?
If not, are you using SMB, FTP, DLNA, or UPnP etc.?
Are you talking about Playlists or Custom Collections?
Where are you seeing “only 14”? Home screen, library, etc.
  • Infuse 8.1.7 on Macbook Pro (Sequioa 15.5), iPad 18.4.1, ATV 4K (18.5)
  • Yes, I’m using Plex, but the list are made weeks ago.
  • Direct mode
  • SMB for my hard disks on my macbook
  • Seeing this on the Collections screen
  • Custom collections
Screenshots:
Does anyone has a idea?
I also face the same issue, the sync does not show all the latest files put in google drive folder when opening infuse on Apple TV.
I then have to open infuse on MacBook and then infuse sync better there.
there looks to be an issue in iCloud sync.
