Hello,
This might be asking too much but I have to ask the question.
I use infuse on several different devices and sometime hop between them mid show or season. I ham finding that the sync frequency of the libraries is not sufficient to do this seamlessly…or even close to seamlessly. most of the time even refreshing the library is insufficient for infuse to log where I am in a show so that I can pick up from the same timestamp or watch status on another device.
I currently use iCloud syncing. Is there a better way to do this or am I just expecting too much? can sync frequency be increased?
2x Apple TV, 1x iPad Pro are my main infuse devices.
thanks
Charlie.
iCloud background sync has been vexing some folks of late. Nothing much to be done at this time other than to trigger a sync manually (libraries tab) before shutting off in one room and picking up in the other (and then updating in the new room).
Cheers for getting back to me. Will try to make the effort to manual sync more regularly.
Usually watched status will sync pretty quick after watching (or stopping mid show) but the catch for going to another device and picking up where you left off is that copy of Infuse doing the scan and sync before you start watching the video you left on the other device.
If you go to the second device and go directly to the library settings page where you can see both the scan status and the iCloud sync status and wait till it completes both you should then be able to pick up where you left off on the first device.
