Support markdown in forum posts
Is support for markdown parsing possible in the forum?
Enabled, and should be working. :wink:
Enabled, and should be working. Wink
Are you serious? Just like that?
Edit:
I’m not seeing it?!
Edit2:
I’m seeing some of it! Is quoted text not supported via the greater-than character?
Quoted text??
More quoted text??
Fixed. :slight_smile:
Amazing—thank you!
You’ve just made quoting small pieces of text infinitely simpler, especially while travelling on public transit. Also, the markdown muscle memory is real.
