[quote="james"]
The update should be available within the next hour or so.
[/quote]
is seas0npass 0.6.4 the fixed version?
[quote="james"]
[/quote]
I see an update for seasonpass now, but when I try to update it I get an error that says the update is improperly signed...
Also, once the update is released, will we need to re-jailbreak from scratch, or just re-boot while tethered?
[quote="eliehass"]
[/quote]
you will need to re-jailbreak it
I have this same issues using 0.6.4. My guess is no...
Guys I did the JB but now my ATV 2 doesn't connect to the Wii net work!!!
Any Suggestion, I want to install the aTV Flash :(.
Ca
install stock ios 4.2.1 in dfu mode
Juts another jailbreak
connect via ssh mode
$ssh root@ip.address
password: alpine
#apt-get install -f
but, this doesn't solved any problem to install package softwares. Are missing firecore source in the apt-source
0.6.5 is the latest version and can be downloaded here: http://support.firecore.com/entries/387605-jailbreaking-101-seas0npass
Could you please post the correct link? .6.5 is not available at that link and we are all waiting :).
You can try clearing your browser's cache, or use the alternate link below.
has not worked. It seems 0.6.5 jailbreaks the device and it wont boot up after that (without tethered boot), but when i finally do a tethered boot, there is no nitotv or jailbreak visible in the user interface.
The jailbreak itself actually has no visible components. You will need to install aTV Flash (black) or other apps once the AppleTV is jailbroken.
[quote="james"]
[/quote]
oh! yeah! of course! omg! its 5am in the morning here and im jailbreaking and waiting for your new version for hours now. sorry, im just too tired :D
good work! thank you very much!
This latest version gave me an iTunes error 1601 and failed at "Preparing Apple TV for Restore." I'm following all instructions...
/sigh. As a computer scientist I totally understand the beta phase though - keep up the good work guys.
NOTE: Do not attempt to run this software while an iPad is plugged into another USB port - I unplugged my iPad and the 1601 error disappeared.
Verifying restore now...
[quote="james"]
[/quote]
0.6.5 works with the latest atv flash black, so do the addons, thank you very much :)
New Seas0npass made it possible.
Two minor glitches, the new saes0npass put the ispw into the root, but iTunes looks in ~/User/Documents - not into the root, and asks to manually select the patched ispw.
And if you already have the previous in ~/Users/Documents/Tethered you make a factory restore.
Love the Interafce - great !!
First installation had same problem as the others, tried the second Seas0npass file and now my ATV2 is stocked to the apple logo with flashing light.
What can I do?
