Step 1: With aTV Flash (black) installed, navigate to the Maintenance --> Settings --> Manage Backups menu.
Step 2: Select the ‘Backup My Firmware’ option.
Step 3: Firmware signatures will be saved, and a list of previously saved signatures will appear below. (Note: firmware signatures are also saved automatically when installing or updating the Maintenance item)
( latest Seas0nPass )
Step 1: Connect AppleTV via USB
Step 2: Launch Seas0nPass
Step 2: Right-click the ‘Create IPSW’ button and select your desired version.
Step 2: Seas0nPass will handle fetching saved signatures and restoring the firmware automatically.
Thanks. I will try it. One more question. When i connected USB to ATV2, this time is connect Power cable too?
Thanks. I will try it. I have questions. When i connected USB to ATV2, this time is connect Power cable too?. What seasonpass version did you jailbrake it. It auto go to Itune and get error . No luck.
Yes, I use aTV Flash (Back) and backup my old firmware 4.4.2. But, I can not use TinyUmbrella. I means, I use this soft, it is have nothing on there. I can not go through on TinyUmbrella. I give up. Sad. Thanks anyway.
I try to backup like this, but it just have IOS 5.0 9B179B (latest)
So it mean if you have use atv flash before, you have backuped one time on the past too, then you upload to 5.1 and go back, so signatures still there. Not me, im update from 4.4.4 (i buy new apple tv, never jailbrecking) then upload to 5.1 directly. Maybe it is not possible for me to update to 4.4.4?
so i hava been do with your step,can success down5.0 to 4.4.2,but when up to 4.4.4 ituns show the error 1600,1602,1604,the device always in duf mod can’t exit;when i use iFaith-v1.4.2 to export the shsh,can see the device been in 4.4.4,just the duf mod can’t exit
Can you explain deep details on step #3. Please!. Or You can writing Intruction Step by Step. I tried to many ways to upgrade from 4.4.2 to 4.4.4 without luck. Thanks
For those who succeeded, did you get your Apple TV 2 used? If so, is it possible that the previous owner uploaded your 4.4.4 shsh codes to Cydia without your knowledge? It seems odd that your 4.4.4 shsh blobs all of a sudden appeared. Thanks.
