subtitles offset doesnt work anymore
hello, i noticed that for quite some time now the subtitles offset function doesnt affect the timing of the text at all. is this a known issue, or am i doing something wrong?
infuse 6.3.6
also is there a way to make infuse prefer embedded subtitles before automatically downloading from open subtitles?
thanks
Hi, I have a similar problem, for some reason it is very difficult to align the delay of the subtitles with the audio dialog, sometimes when the subtitle version isn’t available, I choose an alternative (in opensubtitles.org) and try to adjust them.
It is almost impossible.
Also, I would like to know what is in what units are the increments displayed:
For example, if I select -10.4 the offset is in milliseconds, second or has to do with the frames?
