Subtitles LTR/RTL problem
Great great job on the media player :slight_smile:
One last problem that I found in the subtitles, when I use Hebrew - 1255 encoding the punctuation in the end of a
sentence is in the wrong position,
for exemple:
Word? (?מילה)
will show
?Word (מילה?)
Hebrew & Arabic are RTL and not LTR, that is probably the reason…
Can you please find a way to add a property that will fix it?
Thanks in advance
i agree ! this will help me too… thanks!
Sorry, we’ll take a look.
Hi, James
Thanks for your reply, If you need any beta testing for the solution - I’ll love to help :slight_smile:
Any update?
Just installed the last update hoping to see this solved, but it’s not :frowning:
When do you think you get to this?
Would you be able to open a support ticket and send in a sample file you’re having trouble with?
