Subtitles light gray color or brightness slider
Hello,
Please add one more color light gray for subtitles.
or something like panasonic blu ray has brightness slider.
Thank you
Agree. Сurrent white color is too bright, especially for OLED, but grey color is too dim. Need something average, like default atv subtitles
I agree: white for Oled is really too bright to the point that is distracting and it’s a sore for the eyes.
PS Don’t forget to Like the first post: it helps the suggestion to be considered.
Or something like panasonic blu ray has brightness slider this is great function.
I like the way apple tv’s subtitles work in dolby vision mode. The subtitle brightness adjusts to the brightness of the picture, which means it’s not as bright in dark scenes. Unfortunately, it doesn’t work that way in standard HDR. But it’s still not so bright.
In any case, in the current form, the subtitle settings in infuse 6 are much better than those of competitors (where they often do not exist at all) only lack the ability to choose from more gradations for white and gray and background transparency. When the developers add this, it will be great :slight_smile:
Guys we need more votes :slight_smile: brightness slider this could be awesome function.
light gray it is in beta :slight_smile:
In my opinion light gray is to much dark I think should be added another gray option like
205 205 205
https://rgb.to/rgb/205,205,205
The current Light Gray color is (195, 195, 195) which isn’t too different (205 top, 195 bottom).
Screen Shot 2020-09-28 at 2.19.11 PM
An alternative way to get dimmer subtitles would be to select White as a color, and then use the new Opacity option (set to Semi-Transparent).
Blee :smiley: I dont like.
You know what 225 225 225 I think this can be good as new “light” gray.
OR something like function in panasonic blu-ray subtitle luminance:
The color has been changed to 225 225 225 for the upcoming 6.5.1 release. :slight_smile:
Yep I noticed yesterday. Thank you for listen.
@james
You don’t think colors like light gray /gray should be after white color on list? :slight_smile:
