Subtitle discovery does not work as expected when two versions exist in Plex
Hello,
I am seeing an issue, where if there are two versions of the same video (like a theatrical and extended cut) in Plex, Infuse is unable to find external subtitles properly. Plex correctly finds the subtitles.
So, let’s say:
Battlestar.Galactica.S02E10.Pegasus.mkv
Battlestar.Galactica.S02E10.Pegasus.Extended.mkv
Battlestar.Galactica.S02E10.Pegasus.Extended.bg.srt
Plex correctly shows the Bulgarian subtitles for the extended version, but Infuse does not.
A quick solution is to use MKVToolNix to embed the subtitle in the mkv file
That’s not a solution, that’s a workaround.
We’ll take a look. Thanks.
Thank you!
This should be resolved in today’s 6.2.3 release.
Please let us know if you are still experiencing trouble.
Amazing, thank you for the quick resolution!
