Subtitle delay/offset option missing
I’m using Infuse 7.4.7 on an Apple TV 4k 1st gen, with Plex as an input.
I am used to having the option to change the subtitle delay/offset in the subtitles menu, but that option seems to have dissapeared with one of the (recent?) updates?
This is a critical feature for me as it’s not always possible to find the right subtitles for my media. Is this a known bug/regression?
Not all subtitles have those options.
Thanks for the quick reply!
I tried downloading external subtitles and they did have those options back, so you’re right it does depend on the nature of the subtitles.
I’ll mark this as closed as it’s not an issue then :+1:
