Subtitle adjustments missing
Subtitle opacity and colour settings are gone now in macOS app? How can I adjust them?
What type of subtitles are these?
Some subtitle formats are graphic based with hardcoded styles, and these will have limited customization options.
If you are using something like SRT then all customization options will be available.
They are PGS formats.
It would be nice for a deaf viewer like me. Panasonic UB820 player has the option to do that so do Kodi player. I like the Infuse app because the playback is better but some movies have a bright subtitle by default. The UB820 has a subtitle luminance control to dim the subtitles. I can’t switch the disc anymore btw , in case you’re wondering.
Thx B
Example:
HEAT on the tv
Unable to watch it in a dark room because the subtitle is quite bright.
Panasonic UB820:
-PGS subtitle-
Kodi player has this feature but hidden.
It would be great if your team could add this feature.
Yes please. Subtitles are so bright in HDR in some cases that my spouse risks getting a migraine, and I personally feel my retinas getting burned. LOL. My number one problem with Infuse these days.
